strut lengths
From Brisbane
Hi
I've just been down the wreckers to measure struts on different datsuns, since there was some uncertainty.
120Y - 44.5cm
180B - 44.5cm
200B - 44.5cm
Nissan Bluebird - 46cm
Stanza - 47.5cm
Datsun C210 - 44.5cm
R31 Skyline - 40.5cm (different hub set up, disc is further away from strut, but same bolt spacing on the bottom - 9cm)
Hope this helps,
justin.
Posted on: 2003/4/9 1:14
Re: strut lengths
From Melbourne, Australia
ah ha
thanks heaps
i now know my theory on why i have positive camber is correct!
where is that measurment from - to
Posted on: 2003/4/9 11:16
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: strut lengths
From Brisbane
Hi,
the measurement is from the strut top - where the shock is screwed in - to the bolt holes at the bottom where the steering linkage bolts up.
j
Posted on: 2003/4/10 15:18
Re: strut lengths
From Brisbane, Australia
I don't mean to be critical, but that's not a particularly meaningful measurement. Installed height will vary depending on the seat pressure of the spring installed in each strut.
better measurements would be the length of the strut tube, and height to spring perch. That allows you to see the relative travel available and the effect on ride height using your current springs. obviously there are also the different sized spring bases to take into consideration.
Posted on: 2003/4/11 1:22
