« 1 2 (3)
Re: front disk brake upgrade
From Burpengary
"If that were the case I'd expect to see wilwoods specifically not recommended for dirty applications."
ROFL
Posted on: 2007/10/13 0:26
From Burbank, CA
I may have learned something then.
I find nothing specific about the wilwoods being DOT or otherwise.
For that matter i can't tell if brembo brakes are DOT either.
datsun's are easier to work on than chevrolets!
Posted on: 2007/10/13 3:35
|||\ 81 KPB310 /|||
From Burbank, CA
more research...
old wilwoods say pre 2004 did not have these 'dust seals'
Question: Are they DOT approved?
Answer: No brake system is DOT approved
Question: Don't the calipers need dust seals?
Answer: No, I know of no reason for an additional seal, the O-rings completely seal out dirt,
water, dust etc., air can not get past the o-rings.
so...
these certainly aren't definitive, but more to think about.
Seems to come back to this, don't do this to your mother's car, only do it to a vehicle that is maintained by someone that can determine if there are problems that would not occur on an oem setup.
Posted on: 2007/10/13 5:21
|||\ 81 KPB310 /|||
« 1 2 (3)
