1200 engine
Not too shy to talk
From Johannesburg, South Africa
Hi
i realy need some advice, i own a 1975 datsun 1200 deluxe. I live in South Africa and i would like to find out what i can do to the existing engin to get more power out of it. Ps I can't afford expensive things like a turbo etc.
thanks any advice would be apreciated
Posted on: 2007/10/19 16:09
Re: 1200 engine
From South Africa
2x SU side draghts, branches, freeflow, modified airbox or race filter, blue print motor and reprofile cam.
Posted on: 2007/10/19 17:47
___________________________________
2006 Ford Bantam
2004 Ford Ikon
Re: 1200 engine
Not too shy to talk
Would this not cost me a lot and if not could you direct me to someone in south africa that could help me with this
Posted on: 2007/10/19 17:54
Re: 1200 engine
From South Africa
Without the blue printing (Balancing), +/- R6500.
Try SAC (Steves auto clinic), I might be wrong, but I think they are one of the best.
Heres a link to there site: Steves auto clinic
Posted on: 2007/10/19 18:04
2006 Ford Bantam
2004 Ford Ikon
Re: 1200 engine
Not too shy to talk
Would doing this be cheaper than replacing the engine with a 1400 or a 1500 and will it give me the same amount of power as a 1400 or 1500
Posted on: 2007/10/19 19:51
Re: 1200 engine
Carb & Exhaust might make an A12 as quick as a stock A14.
Your best performance per Rand will be to swap a larger engine -- a stock KA24E engine swap will outperform a modded A14 or A15.
Read this:
http://wiki.datsun1200.com/index.php/Engine_buildup
http://wiki.datsun1200.com/index.php/Engine_Swaps
Posted on: 2007/10/19 21:23
Re: 1200 engine
Not too shy to talk
If i replaced the engine with a stock KA24E then i would probably have to replace the diff and the gearbox.
Posted on: 2007/10/20 7:02
Re: 1200 engine
Not too shy to talk
How much would it set me back(cost) to replace the gearbox and diff etc.
Posted on: 2007/10/20 10:01
Re: 1200 engine
If you go with an A14 or A15 you will also need to replace the gearbox and differential.
If you go with a larger engine, just make sure the gearbox is included. Sometimes a bargain can be had by buying a wrecked car.
Posted on: 2007/10/20 17:15
