« 1 2 3 4 (5) 6 7 »
Re: mean a15
From gold coast
also would a single 42-45mm side drauft webber be better the twin 40-42's?
Posted on: 2007/10/22 2:57
Re: mean a15
From Wagga Wagga, NSW
definately not single sidedraught= 1 ventury per 2 cylinders twin sidedraughts=1 ventury per cylinder so even if you had a big single it would have to be double the size to produce the same figures as twins but would not respond very well at all
Posted on: 2007/10/22 7:20
Re: mean a15
From gold coast
rito thanks
Posted on: 2007/10/22 7:37
Re: mean a15
i reckon to get the best performance out of your A15 carbie wise i would go twin webers but then to top the webers would be quad motorbike carbs but thats a fairly fiddly setup to get goin nicely but are pretty darn mean
Posted on: 2007/10/22 8:21
Re: mean a15
From gold coast
so has anyone got a good idea of a budget i should have for a full build from jts?
Posted on: 2007/10/23 12:09
Re: mean a15
From sydney
Without wanting to be a smart arse I offered you a fully built motor for $2300 and you couldnt afford that much, to rebuild one to the same specs would cost double that.
Posted on: 2007/10/23 12:17
Re: mean a15
From gold coast
no i said ill sell my buggy and see...i also said money isnt a issue...ill pay anything as long as it has atleast a realiable 150hp...ive gota buggy forsale for 7800 and that seems as if it will be going soon..so with 7800 i think ill afford a decent motor dont u?...also got perants
Posted on: 2007/10/23 12:36
Re: mean a15
From Mudgee NSW Australia
Why not buy Sidedrafts already built A15 for $2300 to build a simaller engine would be costing way over $4k. Then you have to buy a set of carbs dizzy extractors ect ect its going to be quite expensive. Even if you where to spend say $2500 on a basic A15 build it wouldnt get you that much.
Out of interest I had twin 45mm webbers on my A14 they where fine you just need to jet and use correct size chokes ect.
Cheers Andrew
Posted on: 2007/10/23 12:39
If In doubt run more BOOST
Re: mean a15
From gold coast
because mine motor is pretty much brand new so wots the point? i have everything done to mine except a decent bore,cam and 40mm webbs...so i think its more logical to do mine...
Posted on: 2007/10/23 12:42
Re: mean a15
From gold coast
btw he sold the motor the same day i asked bout it
Posted on: 2007/10/23 12:47
« 1 2 3 4 (5) 6 7 »
