Browsing this Thread:   3 Anonymous Users
whats everyones thought on efi computers?
From Brisvegas, oz
ive decided to go efi and im not really sure what i should do, should i spend the big dollars and get a microtech or should i go the cheaper option......?? please pass on your info. whats evryone else done that efied the a series. i also had a look at megasquirt but couldnt really work out what i needed and how much it ws going to cost? and whats the difference between the microtech lt8 and 12 and so on
i only require a system that will control fuel, dont really need it to be sequential
Posted on: 2007/10/28 4:15
www.camerasplus.com.au
Re: whats everyones thought on efi computers?
From Far, far away
I thought microtech was the cheap option?
They have an LT4 which is fuel only, right up your alley mate. The LT8 and 12 are no use for your application (they are fuel and ignition).
Posted on: 2007/10/28 6:22
From melbourne
What are you wanting out of the ecu
is it for road use or race use ?
do you want to log data?
or is just a simple system to run a car?
Posted on: 2007/10/28 7:10
From Brisvegas, oz
dont really care about the info once its setup. its only for road use and the ocassional race at the drags. i think your right thou i was looking at the lt4 and thats seems the go
Posted on: 2007/10/28 7:14
Why wouldn't you want ignition control as well? It should just be a case of doing an electronic dizzy and then having proper control of it.
Don't buy second hand ones!
Posted on: 2007/10/28 8:12
From Brisvegas, oz
why not second hand units?
Posted on: 2007/10/28 8:14
From Perth
Hey guys.
Im goin the efi way as well. Do I need to change my fuel lines and run a return line??
Im gunna get some throttle bodies from efihardware.com or tweakit.net
Gunna cost about $1300 thou....not cheap
Posted on: 2007/10/30 11:32
From nowra nsw
i want to go efi but at ant cheap have a llok at theses throttle boddies
Posted on: 2007/10/30 12:20
From nowra nsw
EFI HARDWARE
7 Monomeeth Drive
Mitcham Victoria 3132
PH 61 3 9873 5400 FAX 9873 5955
SpeedTechnology@onaustralia.com.au
Pro-race 4 Cylinder Throttle Body Injection Kit
Pro Race Tapered Bore Series
The tapered bore allows the air speed to be accelerated through throttle body for greater scavenging effect netting more torque and power.
Available in three sizes
45/43/40 45mm at ram tube face 43mm across the butterfly and 40mm at the manifold face
48/45/40 48mm at ram tube face 45mm across the butterfly and 43mm at the manifold face
50/48/45 50mm at ram tube face 48mm across the butterfly and 45mm at the manifold face
These castings are manufactured from 601 Cast aluminum and are heat treated before being CNC machined. The butterflies are measured for each bore & precision machined to a 0.0005
Posted on: 2007/10/30 12:29
From nowra nsw
[img]http://datsun1200.com/modules/myalbum/photo.php?lid=14504[/img]
Posted on: 2007/10/30 12:35
