g/box leak
From Toowoomba, Australia
iv noticed that ive got oil leaking from the g/box in my new sr 120y so far iv traced back to were the shifter goes in to the box but i cant see any real evidence of the leak. can anyone help me before i cause some real damage ind if it any help it got a short shifter kit in it
cheers Harley
Posted on: 2007/10/28 11:17
The substitute for cubic inches is forced induction....
wanted fender mounted mirrors 4 120y
& 120y hubcaps
120y 2dr every day driver
120y 2dr project
Re: g/box leak
From gold coast
how bads the leak? all g-box's seep thats a well know fact but how much is urs leaking? my dellow 2t/3t does the smallest bit but which car dont....
Posted on: 2007/10/29 5:56
Re: g/box leak
last monday before i went to get a rwc i got under the car and had a look for oil leaks an there was a little at bottom of the rear g/box seal wiped it of as they do seep a little. then when i was at my bros place on the wkend i noticed the was oil on the bitumen about the size of a cd thats when a started to have a look around and traced it back to where the shifter goes in to the top od the g/box.
So far iv checked the breather pipe its not blocked so the box shouldnt pressurising and forcing out the were the shifter goes in to the box also the oil goes rightup in side of the shifter boot so it must be coming out with a bit of pressure and i cant see an visible cracks so what else could it be
Posted on: 2007/10/29 8:17
& 120y hubcaps
120y 2dr project
Re: g/box leak
here a link to the short shifter that looks same or simlier to to the one that in my car if it and help
clicky for short shifter
Posted on: 2007/10/29 8:23
& 120y hubcaps
120y 2dr project
Re: g/box leak
From gold coast
id say it mite be a seal around ya drain plug/plugs....see if the leaking increase's after driving....let it sit after driving and watch!.....then if it does jack it up and use a l.e.d mechanics light and hava look....pay attention to the washers on ya plugs....mite help...other wise get professional help
Posted on: 2007/10/29 8:51
Re: g/box leak
From Adelaide, Australia
You didnt overfill it did you?
Posted on: 2007/10/29 8:59
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: g/box leak
i havnt filled it since i got it an the oil level is just below the filler bung on the side of the box so hasnt been over filled and oil is only at the rear of the box around the rear seal and the shifter also can u fill a sr20 g/box from the shifter hole
Posted on: 2007/10/29 9:33
& 120y hubcaps
120y 2dr project
Re: g/box leak
iv found the leak it is coming out the the shifter hole and a reasonable amount at that it happens mainly when it under high/extreme loadwould like to know of there should be some sort of baffle below the shifter area to stop this or some thing i would like to know if an y body has this trouble also and i would would like it fixed before i go to the jamboore cheers Harley
Posted on: 2007/10/30 20:51
& 120y hubcaps
120y 2dr project
