« 1 (2)
Re: Tailshaft help
From Flinders View, QLD
I got a quote through Hardi Spicer for a brand new custome shaft with heavy duty uni's for $450. This was to suit a SR20DE in a 1200 ute fitted with a R31 diff.
Its worth it if you ask me. You can call the nearest Hardi Spice with what you want and get them to ship to you. Dont go cheap cause bad vibrations get annoying and a broken uni can be very embarrising and DANGEROUS
Posted on: 2007/11/6 7:07
Just trying to put the bloody puzzel back together
Re: Tailshaft help
Quite a regular
From Middle Of Australia
Thanks bundy,
I will see how I go.
Any other info others have will be appreciated too.
Thanks Again,
Philip
Posted on: 2007/11/6 7:34
Poster: sunny Date: 2007/4/7 23:40:48
we could round up all the 1200 utes that no one wants and send them to the states.
done the round up, sorry no unwanted ones here.
1200 Ute Project-CA18DET
Re: Tailshaft help
From Adelaide
Pigdog, the r31 unis are small, and the shaft size is only about 2 1/4 from memory, but the tube is a bit thicker than some others around. I used it on my old ca18det with out a problem. But saying that, it only put out 140rwkw's so now I'm now in the process of getting all brand new shafts made, using 3 inch tube with large replacable unis. You can never be to carefull.
Posted on: 2007/11/7 12:33
Re: Tailshaft help
From Newcastle
yeh im eventuly going to be kicking out some serious power so what should i look at useing scotty as i have never had a tailshaft done b4 i got the r30 box with commdore vs diff housing
Posted on: 2007/11/7 12:38
Re: Tailshaft help
Quite a regular
Scott what replacable unis are you talking about, as much help as you can give would be most appreciated.
Thanks
Posted on: 2007/11/8 7:21
Re: Tailshaft help
From Adelaide
Some uni joints are pressed and crimped into the housings, so can not be easily replaced when worn.
Replacable unis have a retaining clip or cer-clip fitted to the uni, so when to clips are removed they can be carfully knocked apart.
Some Nissan/Datsuns have replacible unis, and some have press/crimp unis.
Posted on: 2007/11/8 11:02
Re: Tailshaft help
Quite a regular
Thanks Scott what unis should I be looking out for and any places you know of for part/work in SA would be nice to know as it is an easy place to get parts from to here.
Posted on: 2007/11/9 5:32
Re: Tailshaft help
From Western Sydney
Sorry, anyone know a good place in western sydney for shafts?
Posted on: 2007/11/9 6:53
Re: Tailshaft help
From Adelaide
one4dato
PM sent
Posted on: 2007/11/9 11:47
« 1 (2)
