« 1 (2)
Re: wardats 120y sleeper
From Toowoomba, Australia
what turbo are you using in that setup
Posted on: 2007/9/10 12:41
The substitute for cubic inches is forced induction....
wanted fender mounted mirrors 4 120y
& 120y hubcaps
120y 2dr every day driver
120y 2dr project
From In front, and pulling away.Sometimes around Sydney....ish!
Wade, the fitting on the bottom of the wastegate would have been for an adjustable boost set up, but it appears that the wastegate mount has been changed (I think?) to prevent the waste gate closing fully. When I had it dynoed, the tuner originally thought it had a broken wastegate spring due to it's boost curve. I'm glad to see that it's on and running.
Posted on: 2007/9/10 12:45
Lifes good when your on BOOST!
From Wagga Wagga, NSW
my 120y is also that colour and is also granny spec but its a sedan .......but no turbo
nice work mate i reckon 120ys and 1000s make the best sleepers
Posted on: 2007/9/10 12:52
From south coast, nsw
ok time for an update, since last post i have started to stray away from the sleeper look, the car is now fully regod and has an engineers certificate for the a14,turbo and racing front seats. and i have also fitted a sunny front brakes and strusts with lowered king springs.so here are afew recent pics..
Posted on: 2007/10/14 10:07
From nowra nsw
hay bra oy i seen you the other day in this you were going to the caltex pertrol station its sounds mad
Posted on: 2007/11/11 10:58
« 1 (2)
