Quite a regular
From Calgary Alberta Canada
Oil colour can no longer be used as an indicater of oil condition. New conventional and synthetic oils have changed. They go blacker much earlier than they used to. Synthetic oil breaks down the carbon molecule to carry it (more harmlessly)thru the oil's entire volumn. (goes blacker sooner). Conventional oil carries the whole carbon molecule around, but seperates when sitting. (lite on top, dark towards the bottom/ lite colour on dipstick. Crankcase ventilation also effects oil colour. The stock 1200, Positive Crankcase Ventilation system does a good job when working properly. Excessive crankcase gasses (unburn't hydrocarbons) are vented into the intake at the correct time, to be burned in the cylinders. On a stock or mild performance engine a stock PCV sytem works well to prevent excessive carbon buildup in the engine & engine oil, allowing it to appear cleaner longer. Did you replace your pcv valve, & check all PCV hoses after your engine rebuild? When you modify an engine for performance, the whole PCV thing often has to go by the wayside. A race or 'hot' street engine cannot use a PCV system. The crankcase pressures are much higher at higher revs so the stock PCV can't keep up. The system must be opened up into a catch can and become externally vented. You also need one of those cute little chrome filters for the 'in' side of the system. If you are running your car on the street, and it is stock or mildly tuned, use the stock PCV system, it works well and has no effect on horsepower. If you have a hot engine (twin carbs/cam/extracters), and are constantly at high revs, you'll haveto use an open system. High revs, richer mixtures, less crankcase venting, higher temps, all = darker engine oil sooner.
Posted on: 2007/11/25 18:37
