pod style filters
From brisbane
What do you guys think of the Ram Flo, K & N, Unifilter etc style pod filters? Do you use them? Are they only good for sucking hot air or are they worthwhile when used with some cold air ducting?
I have just bought a 1200 ute and would like to fit one to the standard carbie with the view to also putting it on a Weber when funds permit. Am I able to use the same one or will I need to purchase a bigger one for the Weber?
For the people who have used these style of filters did you use a small filter for the rocker cover breather pipe?
Thanks and sorry for so many questions.
Matty
Posted on: 2003/4/30 7:24
Re: pod style filters
I reckon your best bet is to use a high-flow replacement for the standard filter (like a foam or K&N element) and make up cold air ducting from the front of the car.
Like you said, if you just stick a pod on top of the carby, your just gonna be sucking hot air from the engine, and you may even lose power
Posted on: 2003/4/30 8:00
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
From Launceston,Tasmania,Aus
Pod filter's are generaly used on efi cars...
On my 1600 when i put the webber on i went to autobarn and bought the kit to suit.
Posted on: 2003/4/30 8:50
i made up a cold air feed from a c20 van bonnet and tubing with a ram flo filter on the front. I find it good. search for the pics on the site. or i can post them again.
Just have to make up a shiled to stop hot air getting in. Cost effective for what it does.
Good when going down the free way, ive noticed beeter fuel consumption too.
Posted on: 2003/4/30 14:45
Last month's discussion has links to the pics: cold air intake
Posted on: 2003/5/1 7:03
