120y wagon parts
From nowra nsw
went around to get a battery just then and i seen a datsun 120y wagon on its side all bent but still got motor gearbox tailshaft rear light grill all interia and he also has a reconditioned a12 and 4 speed in his shed any won want some parts im getting the gearbox tailhsaft and motor tmozdoes any won wants some parts
Posted on: 2007/11/30 6:20
Re: 120y wagon parts
From nowra nsw
or tell me wat parts are werth taking off it still has the dash
Posted on: 2007/11/30 6:22
From wangaratta vic australia
has he got brake master clynder(i'm desperate)!
Posted on: 2007/11/30 11:06
From nowra nsw
yer its the whole car um im not shore witch bit is the brake master cylinder so do ya have any pics of wat this part is
Posted on: 2007/11/30 22:52
From Canberra
brake master cylinder will probably look a bit like the bottom one, it bolts to the firewall on the other side of the brake pedal. The wagon may or may not have the big black thing (booster). If it does, take that too. there's a split pin holding the rod to the pedal, and nuts on the inside of the firewall holding it on, then just undo or cut the brake lines.
Posted on: 2007/12/1 0:05
From nowra nsw
sweet thanks for that tyrie i was going around today but his not there but prob monday arvo or something
Posted on: 2007/12/1 0:11
the bottom one ,which is the same as my car! how much does he want for it?
Posted on: 2007/12/1 3:19
From Canberra
spark79 have you considered getting one new? should only cost around $100 and then you know its not going to leak. Plus it will look all shiny
Posted on: 2007/12/1 3:34
i'll shop around . Didnt know you could still by them new!.anyhows,thanx 4 you help cheers..........
Posted on: 2007/12/1 7:31
From nowra nsw
im goona by the whole car minus diff
yer prob cheaper to get a new one cause it would cost heapse to get it posted
Posted on: 2007/12/1 10:23
