TRX wheels and/or Brake package wanted
Quite a regular
From Sydney, Australia
As above. TRX wheels wanted in good condition tyres are not essential.
Thanks ben
Posted on: 2007/12/3 3:28
Re: TRX wheels and/or Brake package wanted
From sydney
i have some $200 does and tyres on them but not the best.
Posted on: 2007/12/3 7:10
From Geelong, Vic
ive got a set of TRX mags with full set of centre caps and wheel nuts for $150
and i could work out a brake package depending on what struts you want
Posted on: 2007/12/3 7:33
Quite a regular
ive got some trx wheels now. But im still looking for a stut swap. preferably everything needed but almost anything considered. just a quick question will trx wheels bolt onto stanza struts no worries? thanks
Posted on: 2007/12/4 5:53
From Sydney (Carlingford)
Mate, Lots of different strut/brake combinations available and the guys here seem to have a wealth of knowledge but you probably need to give a bit of info an what is it you are trying to achieve ?
If you currently have a front drum brake set up and just want the basic disc brake setup then 120y or Sunny struts are an easy change.
If you want bigger brakes then 200b or Stanza struts may be the go and this would allow the ability to upgrade to bigger disks and calipers in the future.
There are plenty of other bigger, better and more expensive options, but how much have you got to spend ?
Yes TRX Rims will go on Stanza struts with no problems.
Posted on: 2007/12/4 7:00
Quite a regular
thanks so much. i currently have late model 1200 disks on the front but am looking to upgrade. i have around 700 dollars to spend can you point me in the right direction?
Posted on: 2007/12/5 2:41
From Geelong, Vic
seems as your running TRX rims, might as well go to the bigger struts
so first on your list of things to buy would be
late ute,late 120y stanza or sunny control arms
stanza or sunny steering arms
stanza or sunny balljoints
stanza or sunny tierod and outer tierod end
late ute or late 120y castor rods
then you can bolt most of the bigger datsun struts straight in, such as the 240k struts you have for sale
so that $700 covers all the suspention stuff too i guess?
and are you planning on doing anything to the rear brakes?
Posted on: 2007/12/5 3:18
Sounds to me like good info from pigdog. Didn't realise you already had 240k struts so with the extras pigdog mentions you are almost done and should be plenty of money left over.
Posted on: 2007/12/5 10:35
Quite a regular
but the 240k struts need alot of stuffing around to make them work, so im thinking of just going the stanza route. what exactly is involved with making the 240's work? new spring cups etc?
Posted on: 2007/12/5 10:53
From Geelong, Vic
alot of stuffing around??????
only thing you need to do over putting stanza struts in is new spring cups,no etc at all only one thing needed to do.....not exactly rocket science
then you end up having a strut that will actually allow suspention travel
Posted on: 2007/12/6 0:46
