Intake plenum
I have decided the ute is going turbo'd and injected, and I am starting to collect bits.
Can anyone here make me an intake plenum for an A15 that I can adapt a single throttle body to? Or does anyone know anyone who sells them?
Posted on: 2003/5/4 6:50
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
Re: Intake plenum
From Tassie, Australia
A decent metal fabricator should be able to make one up for you. Only problem is you would have to design it for your requirements. Surely some of the performance shops over there (on the mainland) could design one for you, but of course whats the cost going to be??
Posted on: 2003/5/4 12:53
Re: Intake plenum
Check out the Tech Section article Supercharging and Turbo-supercharging for some ideas. Also use the search box for marine fabricator where I think this was discussed.
Posted on: 2003/5/4 18:41
Re: Intake plenum
Yeah, I can design my own and get it made if I have to, but I was kind of hoping that someone has already designed one and sells them. Would be a lot less hassle is all
Posted on: 2003/5/5 2:04
Re: Intake plenum
From brisbane
I can not remember the details but I can remember someone talking about forklifts running injected a14s. Sorry I dunno the details
mely
Posted on: 2003/5/6 0:47
Re: Intake plenum
Good point. Nissan made a plenum with single throttle body:
Posted on: 2003/5/6 3:12
Re: Intake plenum
Yes, but where in hell would I find one of these!!!!
Posted on: 2003/5/6 3:51
Re: Intake plenum
1200rallycar has one ... 'course he's got one of everything: gx hood, 2-dr sedan, etc.
Posted on: 2003/5/6 6:10
Re: Intake plenum
From Melbourne, Australia
i was gunna say, theres one sitting in my shed...
Posted on: 2003/5/6 9:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Intake plenum
From sydney australia
maybe the easiest way is to get a twin su gx manifold,then using that as the inlet runners,fabricate a large plenum to bolt to the runners.this was done by a friend with a supercharged 1200 ute(the one used as an example of 1200 versus 1000 front suspension).just making the plenum would be easier than also fabricating the runners.as for injectors,weld-in injector bosses are available from injection perfection,& should also be available from other sources.you could try using a ca20de manifold for bits & pieces,as these are very unloved,& should be cheap to buy.
Posted on: 2003/5/6 12:16
