1200 Ute Rotary?
From Nyngan, nsw Australia
Looking through the forum and seeing a few 1200's with ca18 and sr20's motor,
Not liking to cut away the gearbox well,
So rotary looks a better way as there small and compact, BUT the front mounting is a worrie i think!!,
The rotary h/cuts are alot cheaper than nissan cuts,
Any tips will help on the engine mount.......
Posted on: 2008/1/6 20:04
Re: 1200 Ute Rotary?
From Melbourne Vic
hmmm i thought that rotary half cuts were about the same as the nisssan half cuts, if we're talking 13b turbo... the gearboxes are huge and definately require a new tunnel anyway! its the motor thats compact. see ANGE's car in the photo album, he's done a nice 12a conversion
Posted on: 2008/1/6 20:38
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Bendigo, Victoria, Australia.
i think that u may find a 13b turbo extremely hard to engineer and register. even a 13b will be hard enough.
i am a fan of the rotary engines, but they have their place, and its not under a datsun bonnet.
anyway if you really want a rotary i would start with a 12a non turbo, get some mounts made up and a radiator to suit put in, cut tunnel to fit a gearbox (most likely) build a fuel system (depending on if your're goin injection or carby as to how much work is in that) and make some engine mounts etc etc.
after all that try get it engineered and a RWC. then and only then, would i ask my engineer about a turbo. and if a turbo isn't an option then start building a nice periph-port or bridge-port or something similar, that will keep you on a one block radius of a fuel station.
Posted on: 2008/1/7 0:20
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From Wagga Wagga
Rotary's are hard to work with and are a bit....
if want a good engine try a 4AGE (non rotary). 4AGE 20V: The engine makes 118kW at 7400rpm with a fairly linear power curve.
Posted on: 2008/1/7 3:13
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
yes maybe your right, i think i was thinking out LOUD....
Well this is what im looking for blokes like your self that have been there done it, most of you have,
how about CA18DET any good with the 1200 ute's
that guys for the replys...cheeers
Posted on: 2008/1/7 3:25
From Newcastle
ohh yeh i ate a big red candle . . . . ..
cumon guys its off anchorman lol
Posted on: 2008/1/7 4:10
O OK yep
Posted on: 2008/1/7 7:16
