1965 L320 truck (U.S.A.) ,it's badge says 1200...
It boasts a whopping 60 hp , it says 1200, but I can't find anyone else with anything similar in this club. I want to replace all my oil seals, and gaskets but I can't find them anywhere. do I have to cut them myself? does anyone have a template? Joel
Posted on: 2008/1/16 21:44
Re: 1965 L320 truck (U.S.A.) ,it's badge says 1200...
From Albuquerque NM, USA
Joel,
it sounds like you have a 321/320 pick up.
Can you find the engine # on the block? It is usually on the right hand side of the block towards the back where the tranmission meets the block. Also where it says it has 60hp, was there anything stating the month and year the truck was built? it would be the same type of placard. Oh, also the engine # will start with a letter, Might be the letter "J".
If you can post that info I'll see if I can find some part #'s for ya.
Kelmo
Posted on: 2008/1/17 1:19
The Datsun L320 is discussed quite a bit in the following USA web site: http://forum.ratsun.net. They are particularly fans of the NL320 "Sports" pickup, but there are some current discussions of the 320 in any case. I suggest posting your questions there.
Posted on: 2008/1/17 3:15
From Toowoomba, Qld
hey joel, I drive one of these as a daily in Aus, its a 63' 320 ute running a J15. I have the original nissan parts manual for em if you need to find some bits, the numbers might still crossreference through nissan. let us know what you need and I'll try to get some numbers
Posted on: 2008/1/31 0:01
