Browsing this Thread:
1 Anonymous Users
Serial Numbers |
Not too shy to talk
From Hobart, TAS, Oz
I'm looking for a the section on this page where the serial numbers for the engines are kept. Can't seem to locate it.
This is what I have:
6X26B B82
Means nothing to me, hoping it will mean something soon.
Posted on: 2008/2/10 11:33
Re: Serial Numbers |
Perhaps you can help us to help you by
1. Including some basic location information in your profile. There are some differences between countries, so this can help sometimes.
2. Tell us what engine that this number is on. Is it a Datsun engine, or a Nissan? Pushrod, or cammer, petrol/gasoline or diesel? How many cylinders? What car is it in or did it come from? [if known]
I don't believe that we have a dedicated page of serial numbers, but the info you provide will be helpfull when other forumites try to help.
Posted on: 2008/2/10 14:32
Love your Datsun. Treat it well.
Registered Users Contentmaster Usermaster
> have a dedicated page of serial numbers Not really, but we do have information about Datsun 1200 serial numbers: wiki. You can always start a new page for the wiki. Or just add to the page that's already there.
Posted on: 2008/2/10 18:44
Not too shy to talk
basic location information in your profile:
I'm in Hobart.
Is it a Datsun engine, or a Nissan?: Nissan Pushrod, or cammer: Not Sure
petrol/gasoline or diesel? Petrol
How many cylinders? 4 What car is it in or did it come from? I believe it to be from a Datsun Sunny B310, so I am led to believe. Only description given to me when I bought it was early 80's datsun sunny.
Posted on: 2008/2/10 22:31
From Sydney, Australia
It will be an A12 or A14, and those numbers are casting numbers, not engine numbers or head numbers.. Keep looking for the engine number.
I believe you should look around on the side where the distributor is.
Posted on: 2008/2/10 22:34
'71 Green 1200 Sedan CA18DET Project 99.98% complete '71 White 1200 Sedan 20,000mi + A14T (twin 40DCOE 30/70 cam, extractors) Website: http://www.shoeys.com
Not too shy to talk
After giving it a bit of wipe, I struck gold:
J15 955987
I'm guessing there is a difference between the J and the A? I'm also guessing that the 56A gearbox I have now on the 1200 won't fit the J engine? This changes everything, even the ute crossmember I have!
Posted on: 2008/2/10 23:17
J15 was never in a Sunny.
It was in the Datsun 1500 Ute that kinda looked like a Datsun 1600 but a bit more 1967.
Not sure about gearbox swaps, I know that the J and A series are similar in appearance. One of the fellas will know more.
Posted on: 2008/2/10 23:39
Not too shy to talk
So it appears to be mistaken Identity on the part of the seller or it really was in a sunny as part of a conversion that didn't workout....
I'll wait and see if any of the other chaps will know about the gearbox issue. Thanks for your help.
Posted on: 2008/2/11 0:02
J-series engine is the most similar to A-series, the biggest visual difference is that the head is iron instead of aluminum. It is an older design, and none of the parts are the same.
The gearbox bolt pattern (bellhousing) is different.
Posted on: 2008/2/11 1:06
Not too shy to talk
Thanks for the info.
Do you mean that none of the parts in the J series are interchangable with the A series?
What gearbox/s should I be looking for or is this idea of putting a J15 in a 1200 a waste of time?
Posted on: 2008/2/11 1:15
