« 1 (2)
Re: R31 diff info please.
From Flinders View, QLD
Hope he's a little more acurate with the tape measure than me May be I should lay off the beer but so dam HOT up here
Posted on: 2008/2/13 8:45
Just trying to put the bloody puzzel back together
From Gold Coast, Australia
what is the ID of the axle housing R31?
Posted on: 2008/2/13 9:20
Do you mean the inside diameter of the axle tube? If so the tube is 70mm Outside diameter so inside might be around 65mm.
I ran my tape measure over the diff again (sober ) and from disc rotor to disc rotor (not the mounting face's) is 1240mm.
Posted on: 2008/2/13 10:26
From Sydney
When i got my r31 diff cut - i asked them to make it 1405mm. From memory stock is 1395mm.
Using front wheel drive offset rims the tyres scrub a little on the gaurd.
Posted on: 2008/2/14 14:27
nah i meant the inside diameter of the axle housing, as too obtain a tube to slide inside the housing were the weld join will be. so i need an exact measurement if you have it please.
Posted on: 2008/2/17 8:14
« 1 (2)
