BOV question
From Burbank, CA
Can I use a BOV with a blowthrough carb sort of system?
If it's installed in front of the carby? does that make sense?
Posted on: 2008/2/14 3:34
|||\ 81 KPB310 /|||
Re: BOV question
From sunshine coast QLD
i dont c y not. ive seen a few carby setups running BOVs.
Robert..
Posted on: 2008/2/14 4:09
Re: BOV question
From Melbourne,Australia
Im running one on mine with a gas research lpg carby they recomend it to prevent carby backfires
Posted on: 2008/2/14 4:26
Re: BOV question
From Burbank, CA
^^^^ Where was the BOV in the system?
Posted on: 2008/2/14 4:38
|||\ 81 KPB310 /|||
Re: BOV question
well when u think about it putting it b4 the carby is the same as putting it b4 the throttle body on a efi car..
Robert...
Posted on: 2008/2/14 4:40
Re: BOV question
From Burbank, CA
that's what I figure.
I just wanted to make sure I wouldn't have to vent air fuel mixture.
Starting to think about how to actually do my turbo setup.
Posted on: 2008/2/14 4:52
|||\ 81 KPB310 /|||
Re: BOV question
From Brisvegas, oz
when i had the carby setup i used a turbosmart one as seen in the photo .
the setup goes
1 air filter
2 turbo
3 intercooler
4 bov
5 carby hat
6 carby
7 engine
8 exhaust manifold
9 turbo
10 exhaust
but you dont need to run a bov if you dont want to i have read that it is only necesary to have one if you seeking big boost levels over 18 psi. my current system is running fine without one and i get a better sound now (mmmm flutter). then again alot of people will say you MUST have one.
Posted on: 2008/2/14 4:54
www.camerasplus.com.au
Re: BOV question
From Burbank, CA
If you're going through the trouble of making an after market turbo setup, you might as well have a BOV it won't hurt anything done properly.
I can't wait it's gonna be wicked!
Posted on: 2008/2/14 5:26
|||\ 81 KPB310 /|||
