H150 gear assembly in the stock H145 axle housing
anyone out there done this?
how is the best way to get the pitroad spacer...seem to have a challange getting on the pitroad web site...
thanks ! !
Posted on: 2008/2/14 6:39
Re: H150 gear assembly in the stock H145 axle housing
Pitroad seem to want enough money to be a deposit on your next new car for these spacers. Well, OK, they were around $160 US+ when I first saw tham a while ago, but they are more affordable now.
You might have much less drama buying in a few diff gaskets & keeping two for the job & using one as a template to make a spacer up for yourself.
A piece of 2mm alloy shouldn't be too hard to find.
The conversion from 10,500 yen [tax paid] at todays rate brings it to Aus $107-39
Go to the Pitroad website & click on "Catalogue"
then select "A clutch, mission and defense" ['A' series clutch, transmission & differential]
What you want is the last item on the list.
Posted on: 2008/2/14 9:34
Love your Datsun.
Treat it well.
excellent thanks for the info!
Posted on: 2008/2/14 16:56
From Quairading, Western Australia
I have to put a H150 center into The Defect III's early model 120Y H145 housing
and as I'm a cheaparse the spacer will be homemade
I don't have a manual H145 tailshaft and I have a spare 3.889 ratio H150B center out of a B310 sunny lying around
not only that but then the driveline will be A15 ready
Posted on: 2008/2/15 2:45
Do the H150's have a different flange on the diff to suit the tailshaft??
Posted on: 2008/2/15 6:44
Yep, they have a larger flange. There is a comparo picture in the club wiki.
Posted on: 2008/2/15 7:06
