« 1 (2)
Re: Removing rear window from 1200 ute (without any damage)
From Flinders View, QLD
Yeh kinda does actually, cheers for that. I will try and remove the tint with the window still in but if its a pain in the butt then I will just remove it.
Posted on: 2008/2/19 11:28
Just trying to put the bloody puzzel back together
From gold coast aus
as pepper said when putting back in i went to hardware and brought few meters of blind cord soak it in oil so it slides easy push into seal where body would sit and overlap rope top or bottom have some one hold window on outside in position with rubber in place as close as possible with them pushing start to pull string to lap rubber over the body once half way round grab the other end start the other way as for removing tint put some dishwashing liquid in spray bottle fill up with water keep window wet lot easier even more so when it comes to getting the glue of you will need couple off blades to make it easy hope this helps
Posted on: 2008/2/19 11:44
« 1 (2)
