Tail end gearbox seal
Quite a regular
From South Africa
How the hell do you fix this thing i have put in a new seal made sure ther is no dirt or anything where the seal goes in and its still leaking!
HELPPPPPPP!!
Posted on: 2003/5/20 10:14
Old Datsuns never die they just go faster
Re: Tail end gearbox seal
From DUNEDIN
there are firstly two seals one where the
drive shaft goes in and one behind that
i have played with alot of these and found
that the tail shaft housings tend to fracture
quite easy so you might have to look there
Posted on: 2003/5/20 10:36
From Brisbane
check your yoke see if it has engough metal on it, other wise it doesnt hold the seal.
the tailshaft could be bent, chucks the seal out.
also check the filter on the gearbox, if it is dirty i can build up pressure and blow oil past the seal
these are the problem i had with my gearbox
Posted on: 2003/5/20 13:38
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Castro Valley,CA USA
Boo on rear trany seals. Mine leaks too.
My yolk seemed a bit sloppy in the trans. It also seemed like the output shaft was wiggling around too.
I had the trans rebuilt (for other reasons) and this seemed to tighted things up. Maybe bad bearings. The oil still seaps out, but not as much.
Also remember to oil or grease your tailshaft yolk before you install it into the trans.
good luck
angelo
Posted on: 2003/5/20 14:09
