Dont laugh
From Mudgee NSW Australia
Hi guys just wondering if anyone here is into turboing diesels?? I have just bougth myself a new work van- tow vehicle its goes ok unloaded but I feel it needs a bit more pull it has a throbbing 2.7ltr diesel 62kw@4200 and 172nm@2400 I would like to triple this but being realistic a 30-50% gain would be nice. Any sugestions??
Andrew
Posted on: 2003/5/19 13:02
Re: Dont laugh
From Auckland N.Z
ive heard injecting lpg into diesels is like noss for petrol engines. not sure how to do it but it would be good.
Posted on: 2003/5/19 13:23
Re: Dont laugh
the work van on gas would be a laugh. i cant see how it would be good for the engine though I want reliablity too.
Andrew
Posted on: 2003/5/19 13:39
Re: Dont laugh
From Millgrove Vic OZ
My father in Law has a Hilux diesel turbo and it goes every bit of 30% harder. It is faster than the petrol and uses heaps less fuel.
Posted on: 2003/5/19 14:40
Re: Dont laugh
From Boredomville Melbourne
Zoom did an article on boosting disels a while back, just similar to petrol motors (boost, intercooler, Exhaust) but the difference is that hey like to run lean. So they recomend setting them up on a dyno to make sure they run good as they dont have injectors, but that wierd ass fuel metering thingy. Just when i thought Hitachis were wierd ass pices of crap.
Posted on: 2003/5/20 1:40
Was B110 Sedan: L series and 5 speeds, the way they should have been
Now A10 Stanza: L series and 5 speeds...
Re: Dont laugh
From Kyabram vic, aust,
I read an article somewhere about diesels not liking huge intercoolers and that a bigger one is not as efficent as a smaller one.......is this true......maby someone can clear this up???
Posted on: 2003/5/20 5:46
Re: Dont laugh
From Seattle, WA
Diesels are around 22:1 compression. They respond as well or better to turbos than gasoline engines do. Basically you are only pumping air with the turbo, no fuel, which makes things easier as with an EFI engine. All diesels I believe have fuel injection, but often it is mechanical (the "fuel metering" mentioned previously).
All the big trucks use turbos. Some have compound supercharging.
Posted on: 2003/5/20 6:32
Re: Dont laugh
From Charlotte NC USA
if you have 5 or more bolts around each cylinder turbo the thing (soap box ) I strongly recomend you take it to a qualified diesel mechanic that is well versed in setting up turbo systems(off soap box) go for it at the verry least it will not smoke as much under acceleration
never seen an engine I didn't want to soup up
Posted on: 2003/5/20 11:40
Phil (aka nutcase)
I have C.L.W.E.A.
Can't Leave Well Enough Alone
120y exelant clone gone :(
