« 1 (2) 3 »
Re: Supercharger questions
From Christchurch NZ
I hear what you're saying Wayne. Nah, we've just turned up larger crank pulleys. My Dad is always on my case saying we need to make a smaller pulley (for the blower) and crank up the boost. If I do give in to him, we'll have to do what you just described and make a pulley boss out of the inner part of the toyota pulley hub.
Something else kinda on topic,
My mates S/C 12 set up has the blower mounted over and under, with a custom manifold flanged onto the blower intake. (Obviously) He originally had a single 40mm solex mikuni, but couldn't get it to run. So he made a manifold to fit the sidedraft manifold which uses a 32/36 I gave him. ANYWAY, his carb manifold gets really cold after a good thrashing. None of this cold reaches the manifold on the blower because he has a soft mount kit between the two. But it got me to thinking. With my carb being directly over the supercharger, the evaporation induced cooling must be transmited into the blower lobes. One might think that this could prevent the lobes getting heat soaked, and lead to (At least marginally) cooler itake temps.
Posted on: 2008/3/9 8:16
Forced Induction!
From Wellington New Zealand
Ah crank pulley I missed that bit...duh. I have to make one of those too but I am waiting to pull the motor out first. I wiil try and remember to take some pics of the install I'm doing at the moment in a Celica with a SC 12.
Posted on: 2008/3/9 8:32
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
I've posted some pics of the SC 12 I've just fitted to a Celica.
Posted on: 2008/3/10 6:06
1200 ute
Sunny 310 SGX.
From The garage, NZ
niiiceee pictures Mr. Mac. Very clean install. Good to see some pictures from you. A++
Posted on: 2008/3/10 6:19
From Wagga Wagga
i'm putting a v8 in my 1500 ute and was thinking about superchargers but....... i feel that unless you got a v8 you got to go turbo.
Posted on: 2008/3/10 8:10
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
Why is that?
Posted on: 2008/3/10 8:25
Forced Induction!
From Wagga Wagga
well who has herd of a supercharger on a small 4cly?!? anyway I'm after a street machine so something with a bit of grunt not a little hiss!
Posted on: 2008/3/10 8:40
A15 Engine
5 Speed Sunny
H165 Diff
Blowers were first fitted to 4 cylinders in the late 1920's. Ol Henry didn't produce his first bent 8 until 1932...It wasn't the first V8 but blown 4s came first.
Posted on: 2008/3/10 8:45
1200 ute
Sunny 310 SGX.
From Springwood NSW, Formerly Tas.
obviously not you....
Posted on: 2008/3/10 8:54
1978 120y Coupe.
From Perth WA
Been doing some research and talking to other people and turbo sounds cheaper!
I mean i could make a manifold myself just about, just get my boss's mate to weld it up properly for me. Turbos are usualy cheaper then a SC12/SC14 too. Ill just plumb it back into the standard inlet too.
Would do a water/meth system too using the whole washer motor idea. I have a couple of free A12s to play around with and blow up anyways.
Posted on: 2008/3/10 8:57
Chris...
« 1 (2) 3 »
