« 1 (2) 3 »
Re: Can a 1500 hold a V8?!?
From Wagga Wagga
I have herd of one with a ford C6! don't ask me how he got it in there!
Posted on: 2008/3/19 9:14
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
From newcastle, NSW
MY 2 CENTS..................
Stuff the V8! if i were you, i would either work the L16 or put in a worked L20, my mate had a 1500 ute that blew the motor, so he bought a cheap L20 for a couple of hundred bucks, and spend a couple of hundred more on cam and twin webbers, the thing friggin flies!!!!! its only a work ute, but he does fishtails to work!
much easier conversion than a full V8 setup, easliy spend couple thousand on a full V8 setup, L series you can get a kick ass set up for a couple of hundred, $1000 at the most
Thats my 2cents!
Posted on: 2008/3/19 9:38
From adelaide
well I have done 3 engine conversions! thanks to my part time job!
didn't know repco did engine conversions?
Posted on: 2008/3/19 9:41
From Townsville, Qld
Back in the 60's....
Posted on: 2008/3/19 9:48
From Far, far away
Yeah, repco used to make some real kick ass motors back in the day. Some real original stuff too.
Posted on: 2008/3/19 9:55
You have done three engine conversions so far? If that's true, then you should know that it's torque that kills deivelines, not RPM & if the stock driveline could hold a 350 chev engine then it's too big, strong & heavy for the original application.
You also should know that a power upgrade goes hand in hand with suspension & brake upgrades, yet not one single question or comment about either of these things. Not even a hint about rectifying thirty years or more of general wear & tear.
General rule of thumb, ..... upgrade the chassis first. Make sure the suspension & brakes are right up to scratch, ..... then do your engine conversion.
But after three engine conversions, you already knew that.
Posted on: 2008/3/19 12:58
Love your Datsun.
Treat it well.
From perth
exactly wat Dodgeman said.. gee's your a smart man..
just thinking about it now makes me relise more about how much a v8 could or could not work in a dato.. its just gona take abit of work
have a look at this thread and this guy ask about wat it will take to convert a v8 into a gemmi. just a few pointers on wat they use and wat it takes.. one even comments about putting a 253TT into a datto 1200 ute. !!
clicky
Posted on: 2008/3/19 15:53
1200 sedan stock sleeper.
Aero Racing
Talk talk talk... It won't work? Tell that to the dozens of guys running V8s in their Datsun 520s (Datsun 1500 pickups). Did you know the diff is an H190 unit?
Posted on: 2008/3/19 18:00
From Far, far away
DD's right, it is a pretty common conversion for the 520 (and even more so in the 720). But everyone else is right in saying the chassis and driveline need to be upgraded to warrant the conversion. I've yet to see one in Oz that isn't running at least a BW diff behind anything up to 308.
A good conversion would be the old Holden (Buick) 3.8 V6. Cheap (and plentiful) motor, standard diff would be able to take the torque, only minor upgrades needed in the front end, and it would haul ass.
Posted on: 2008/3/19 23:12
From Wagga Wagga
Ok looks like i'll just work the L16! yep all just talk, talk, talk, so stuff this I'm going home and working! catch ya later people! burke_a_lot signing off!
Posted on: 2008/3/20 1:09
A15 Engine
5 Speed Sunny
H165 Diff
« 1 (2) 3 »
