« 1 (2)
Re: Oversize piston question for A15
From Kuantan,Pahang D.M,Malaysia
where can i get this gasket,at malaysia have sell or not??
Posted on: 2008/3/21 19:51
From Christchurch NZ
apizB310 wrote:
how about rb20 piston,78mm bore...
Are they?!!!!
What is the crown shape/pin height/pin dia like?
I have an rb20 at home for parts....................
Posted on: 2008/3/21 20:13
Forced Induction!
From Malaysia
So, anybody with successful RB20 piston transplant around?
Posted on: 2008/3/23 16:42
There's often a lot more to this piston swap business than first meets the eye. You need more than just a suitable bore size.
You need to take into account the pin diameter, & think about what needs to be done to make it fit, then there is the crown height, &
whatever piston or block mods are needed to make that work out & of course the skirt to crank &/or rod clearance is also an issue in some cases.
The crown shape can also be a problem in some applications too, so yet again, another thing that needs to be checked.
Once this is sorted, the ballance becomes the next step.
Sometimes these things work out, sometimes they don't, but with the A15, several piston options are available.
Three factory oversizes [up to 77.5mm bore size] & at least two flat top pistons in 78mm & 79mm bore sizes are available.
Sometimes it's better to figure out what you really want & just get the part that was made to do the job in the first place.
I've gone for 78mm flat top A14 pistons for my short stroke A13.
Posted on: 2008/3/24 1:53
Love your Datsun.
Treat it well.
From Malaysia
Any ideas where can i get the oversize pistons?...Forget about tomei and Japanese links, its quite pricey...
Posted on: 2008/3/24 7:22
Standard oversize pistons should be available through the parts department, or an automotive supply house if you have one you can get to.
Engine reconditioners should be able to source them 'non genuine' & if all else fails, someone in another country should be able to get some for you.
To do this, it would probably be desirable for both parties to have a payPal account or some other satisfactory method of payment.
Posted on: 2008/3/24 9:35
Love your Datsun.
Treat it well.
From Malaysia
Thanks man...ermmm now lemme see where shall i start......
Posted on: 2008/3/24 10:18
« 1 (2)
