Crank Bolts
From Sunshine Coast, QLD
Hey pplz, i have a fully worked A14 which i use to run a std crank in, now i have gone to a A15 Crank, i have 11mm flycuts in piston tops, since running the A15 crank i keep snapping the bolts, any info in the way of wot type bolts i can use, or should i get some made up, currently rebuilding, also will compression be to high as its only bored 80tho not 120, cant afford avgas nemore
Posted on: 2008/4/20 1:54
Re: Crank Bolts
From Darwin NT
arp studs? will work well?
Posted on: 2008/4/20 2:13
current project 4x4 patrol...
Re: Crank Bolts
From sydney.nsw
something not right ive built many race engines using new genuine STD bolts turning 8500rpm 14;1 comp. not broken rods bolts yet
Posted on: 2008/4/20 2:23
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: Crank Bolts
yer not sure wots happening, Bige, do u have ne spare race parts, after a knifeedged A15 crank, or how much to do one???
Posted on: 2008/4/20 2:28
Re: Crank Bolts
From sydney.nsw
best to give me a call 0412 864 741 ernie
Posted on: 2008/4/20 2:48
Re: Crank Bolts
sweet as, busi atm, but i will be in touch mate, might need other things to, thanx champ
Posted on: 2008/4/20 2:51
Re: Crank Bolts
Perhaps the installer overtightened them. Use a torque wrench, and dont go too tight.
Posted on: 2008/4/20 7:13
Re: Crank Bolts
are there tourqe settings on the site or if not wots recommened?? and is there a patteren to tightening crank bolts like wheel nuts??
Posted on: 2008/4/20 10:10
Re: Crank Bolts
What 'crank bolts' are you talking about? Rod bolts, Main bearing bolts or flywheel bolts?
"Crank Bolts" is not really very clear.
I'm guessing that it's in a racer as a "fully worked" engine would quite naturally be totally undriveable on the street & if that's the case, you are probably breaking the flywheel bolts when the revs start climbing over 8,500 or 9,000rpm.
It's a common problem.
Posted on: 2008/4/21 6:24
Love your Datsun.
Treat it well.
Re: Crank Bolts
sorry, flywheel bolts,
Posted on: 2008/4/21 10:14
