1000 grills.i gather they dont interchange?
From Adelaide, Australia
hey guys got a lil 1000 ute and i got a grill of a 2 door i think but funny enough it seems too wide by a few inches. what grills can i use or do i have to change somthing else
Posted on: 2008/4/21 13:04
Re: 1000 grills.i gather they dont interchange?
From perth airport
has far has i know the grills are interchangeable . do you have a 1200 grill ???????????
Posted on: 2008/4/21 13:10
perth airport parking
Datsun 1200 ute A14
From Perth WA
All grills are interchangeable. Utes and early cars have different headlight surrounds though. You cant mix and match.
Posted on: 2008/4/21 13:19
Chris...
Pretty much all of the 1000 grilles are interchangeable as grille & headlight surround assemblies.
There were two ute grilles.
1968 model. [Dec 1967 to Sept 1968]
1969 & 70 model [Oct 1968 to June 1969, then July '69 to Dec '69]
Three grilles for all Sedans & Vans.
1967 model [Sept 1966 to Sept 1967]
1968 model [Oct 1967 to Sept '68]
1969 & '70 models [Oct 1968 to June '69, then July '69 to Dec. '69]
One grille for coupes.
1969 & 70 models. There appear to be two vendors & there are structural differences, but visually & dimensionally the same.
Two headlight trims for B10 models
The 1967 B10 headlight rim was a full ring, was alloy & unique to the '67 [2 door sedan & van]
The headlight rim that was introduced in Oct 1967 was used on all B10 versions after that.
One [possibly two] headlight trims for utes [B20]
The 1968 ute [B20] headlight rim was also a full ring, but was steel & painted a dull gray.
I do not know if it is visually identical with the alloy car one or not.
I do not know if the 1969/70 model ute [B20] headlight rim was the same as the earlier one, but it could well be.
If you really need to know, then contact me & I will look up the parts number.
Posted on: 2008/4/21 17:00
Love your Datsun.
Treat it well.
