Electrical help
Not too shy to talk
From Hobart, TAS, Oz
Greetings all,
first post in a while.
I'm an owner of a '71 1200 station wagon, extremely faithful car. It's been off the road for about 4 months and just todays we have the entire reconditioned engine back in one piece and sitting in the engine bay.
I've come up against a problem, I cannot for the life of me recall the rewiring. All wires were labeled before the battery, solinoid, starter motor, alternator etc. were removed. Everything is back in place and I have rewired to the best of my ability but as soon as the positive terminal is connected I get crackling and spitting from the battery.
I'm in need of some advice and some visuals if at all possible for this please.
Thanks, read from someone soon.
K
Posted on: 2008/4/24 4:40
Re: Electrical help
Not too shy to talk
Let me ask another question which might actually clear up the first question:
If the battery isn't earth to the timing chain cover, will that cause the sparks to fly?
K
Posted on: 2008/4/24 5:00
Re: Electrical help
Nah, it doesn't cause sparks to fly unless something is "on" (like the ignition key). So you may have a short somewhere.
In any case, bolt the neg. battery cable to the engine block. The starter needs a good earth.
Posted on: 2008/4/24 5:36
Re: Electrical help
My money is on the alternator wiring.
Remove the ground wire that you have put on the Positive post on the back of the alternator.
Posted on: 2008/4/24 8:25
Re: Electrical help
Not too shy to talk
What if the connections for the reverse light contacts on the gear box are back to front, would that be an issue?
Posted on: 2008/4/24 9:07
Re: Electrical help
From Bendigo, Victoria, Australia.
no. not an issue. its only a switch on the gearbox.
Posted on: 2008/4/24 11:57
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
