Steering wheel up and down movement !
From Delaware, USA
Hello mates,
Does anyone know where I can purchase the bearing that goes in the steering wheel ? My steering wheel has alot of movement up and down
Posted on: 2008/4/25 12:58
Re: Steering wheel up and down movement !
From newcastle, NSW
I HAD THIS PROBLEM TOO!!!!!
It turns out that alot of the time you may have to adjust the steering box.
Posted on: 2008/4/25 13:03
From Tamworth , NSW
you can get the new bush for the top of the steering column from nissan still.
Posted on: 2008/4/25 13:16
From Portland, OR
Part number? This is info that should go in the wiki. I have the same problem on my sedan.
Posted on: 2008/4/25 22:32
From Tamworth , NSW
i dunno, any of the fellows here that works at nissan may be able to supply a part number.
id suggest if you have the same problem, you trot on down to nissan and just ask for one.
Posted on: 2008/4/25 22:44
From Adelaide, SA
It is in the Wiki
Posted on: 2008/4/26 0:24
From Sydney, Australia
are we talking 'radial movement' or 'axial movement'?
Side to side movement is bearing.
Up and down movement on a collapsible steering column, is the plastic shear pins. This can't be easily fixed. You have banged on the steering wheel, and are left with a broken steering column.
Posted on: 2008/4/26 1:22
From Delaware, USA
Thanks mate for the part # of the bushing colum. I ordered it from the nissan dealer. I got to tell you, you have to love this site if you own a DATSUN 1200 !!!!
Posted on: 2008/4/28 23:46
