Distributor Advance Curve
I thought most engines like a total of 30-36 degrees "total" advance at Wide Open Throttle (WOT).
Why is the stock A12 distributor only 17.5 degrees total (5
Posted on: 2008/5/5 4:23
Re: Distributor Advance Curve
From Christchurch NZ
Good question.
I've been thinking about this lately. I Hope to soon fit my New old stock electronis dizzy. I was thinking About limiting how much mech advance it can get, But I'm very reluctant to butcher a brand new dizzy. How much vac advance do they have? I was contemplating having the diaphram converted to a boost retard unit. Once the nitrous is on, any rattles will mean instant death for the pistons.
Posted on: 2008/5/5 5:50
Forced Induction!
The Factory Service Manual lists the curves and specs.
Anyone have an Aussie FSM?
In USA, all A-series through 1982 are very similar:
- 11.5
Posted on: 2008/5/5 6:12
From Taupo New Zealand
the y axis on those graphs says distributor angle, which as dizzy turns at half engine speed would be doubled for crank angle- is that a possibility?
My manual (not a factory one) says 5-10btdc depending on model, so if you doubled the above you would get anything from 28-35 total which would seem reasonable?
Posted on: 2008/5/5 6:59
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
That seems to make sense...
Posted on: 2008/5/5 7:27
