« 1 (2)
Re: 32/36 blow through setup
To give you an idea about an efi pump, they can produce up to 650kpa of pressure. The internal fuel pressure relief is usually set to around 600kpa (87psi). If you have the base setting on 4psi (27.57kpa) you are effectively forcing the VL pump to bleed off internally at a rate that will overheat the pump to the point of failure. It would be like driving a VL with a set of locking pliers on the return fuel line.
Posted on: 2008/5/20 13:26
From Brisvegas, oz
ill try to explain it in another way. in relation to the difference of an efi pump to a carby pump. would be like using a garden hose (carby) and a straw(efi). the garden hose will obveously be able to fill say a bucket way faster than filling with a straw but the straw would punch out a much higher pressure.... this may have just confused the fuk out of you but its just another way of thinking about it, im sure it would be much smarter to just start with the carter. could you get store credit instead of the replacement or just switch it for the correct pump. and if all that didnt confuse you its like revhead said a reg is just like a clamp. the tighter the clamp the less flow
Posted on: 2008/5/20 13:37
www.camerasplus.com.au
From NSW, Australia
I know what your saying about the EFI pump, but i thought the Rising rate Malpassi regulator has a return line built in for the extra fuel to feed back to the tank.
If so would that be enough to releve the pressure or still to powerful?
Posted on: 2008/5/20 13:39
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
From Brisvegas, oz
i not 100% sure as i dont know everything about everthing, but it may not be as im pretty sure ronald is using the malpassi rate reg he got of me. the reg he is using is a carby reg not a efi reg. i would say the carby regs are only good for carby pumps as it may be working in the same way as as the fuel pumps.
Posted on: 2008/5/20 14:12
From Bendigo, Victoria, Australia.
well here's an update. got a new pump (same as the one before) and put it in. ute ran well for about 10mins then started to play up again, like it is running out of fuel and is getting worse and worse.
i will now take the vl pump back and get a store credit and buy a "carter black" pump to go on the ute. i will also take the tank out and clean it out thoroughly and put some new petrol in.
i guess i admit to being ignorant, but i honestly thought that with a return line in place and the regulator set correctly for the carby that i wouldn't have any troubles with the pump. but i guess you live and learn.
Posted on: 2008/5/21 12:37
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From Brisvegas, oz
as many people know research and development is fukn costly stuff. hope the carter works for you
Posted on: 2008/5/21 12:53
From Melbourne, Australia
there is two malpassi regs...
one is for efi type pressures
one is for carby type pressures
a vl pump is around 75-100psi
a carter is up to 16psi
you need a carter with the right rising reg... or instead of a reg there is a cheaper way which i used but it takes a bit of explaining
any pressure over around 5psi fuel pressure will overcome the needle and seat (flooding the carb)... until you put boost down the carb.... then you need to increase fuel pressure as boost increase otherwise the boost starts pushing the fuel back out the carby
back to what i was getting at before.... after about 7psi the 32/36 will start spitting out gasket quite regularily... spilling fuel all through your engine bay and on your exhaust
so if your serious about blow through carb save yourself more "reaserch and development" and box that carb from the start.... or keep it to really low boost
it's not really reaserch and development... many have done it before
i can help with a fair bit of advice i feel cause i have gone through a lot of it before. if i miss your questions PM me
i have a few carby turbo photos in my gallery if you would like to look
Posted on: 2008/5/21 13:10
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
« 1 (2)
