Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
STRUT INSERTS
bobthebuilder
Posted on: 2008/5/24 6:24
Hi Guys
I am looking at putting stronger inserts into some 120y struts . In an old post I found a reference to commodore inserts being used but they are a tight fit. Has anybody fitted these into 1200 struts and if so how tight a fit are they? Any other inserts from another vehicle worth contemplating ? Thanks Bob
#2
Re: STRUT INSERTS
Graemes50
Posted on: 2008/5/24 8:18
The standard 120Y strut inserts are T1 type which are 38.1mm in diam and have a body length of 418mm.
The Commodore is a T6 type, 44.5mm diam and 405mm long. By stronger do you mean heavy duty? Why not consider the Monroe Gas Pressurised for example, P/N 25-3418.
#3
Re: STRUT INSERTS
Posted on: 2008/5/24 20:33
Gas struts raise the front up a little. They are generally quite stiffer as well.
For alternative choices, see: club wiki - strut inserts You can view topic.
