turbo setup A12.. differential
Quite a regular
From San Salvador, El Salvador, Central America
guys what dif should i use.... i really appreciate any help.. whats the best diferential i can use for a 210 5 speed gearbox and a A12 turbo engine, what axles you recommend
Posted on: 2008/5/28 17:53
Re: turbo setup A12.. differential
What chassis are you using? The 210 model name is the US designation for the B310/Sunny [1978 to '82] & in many markets [including Aust] they came with the A12 engine in non wagon models, however you say that the trans is from a B310, making it a late [conventional shift] 60 series item.
Are you asking about the differential, or the rear axle assembly?
Are you running a racer, or a street car?
Posted on: 2008/5/28 20:20
Love your Datsun.
Treat it well.
Quite a regular
my car is for street races... im using a b110 chasis... datsun 1200 coupe... right now im using a 210 5 speed gearbox. what i really like to know is what dif. should i use for better acceleration and also the ratio..
Posted on: 2008/5/29 9:25
I was reading in a magazine (yeah I know. I Can read) that turbo cars prefer highway style gears 3.23:1 or 3.5:1 as when the turbo spools up in lighter cars the wheels tend to spin too easy. Unless of course thats what you want. Using highway style ratios tends to make more use of the boosted power.
Posted on: 2008/5/29 9:30
From Canberra
I would say with an a12 turbo you wouldnt have to worry a whole lot about excessive wheelspin as it spools up. I doubt he'll be street racing with 155R12 tyres. I would want something in the 4.5:1 range.
Posted on: 2008/5/29 9:44
Quite a regular
FOR QUARTER MILE RACING PURPOSES, WHAT WILL BE THE BEST DIF AND THE BEST RATIO.... MY CAR IS A DATSUN 1200 COUPE B110 .. a12 TURBO ENGINE....RIGHT NOW IM USING A 210 - 5 SPEED GEARBOX. ALSO WHAT AXLES SHOULD I USE.. ALSO IM USING PANASPORT 13 WHEELS ON 175-50-13 TIRES
Posted on: 2008/5/29 9:47
From sydney
I am thinking turbo car needs taller ratio, 3.9 maybe, those turbo cars spin the wheels in all gears they dont need a low ratio diff.
Posted on: 2008/5/29 9:50
From Canberra
Its hard to know without knowing what cars with bigger diffs are common where you are.
Without this information all you can do is look for cars with about the same width rear, that have bigger diffs and appropriate ratios, then make one fit.
Quite a regular
WE CAN FIND PRETTY MUCH ANY CAR... THE PROBLEM IS THAT WHAT TO LOOK FOR... THAT MATCHES THAT RATIO AND FITS THE DATSUN1200 COUPE
Posted on: 2008/5/29 9:52
From Canberra
If you can find a 1200 ute, it has a bigger diff, 4.1 ratio and will go in easily.
Posted on: 2008/5/29 9:54
(1) 2 3 »
