do L300 discs fit on 1000's
From Adelaide, Australia
heys guys heard that L300 front disks fit on 1000's. anybody done this? i have noticed they are 5 stud
Posted on: 2008/6/1 6:40
Re: do L300 discs fit on 1000's
Definitely 5 stud. No one has confirmed the C22 or Nomad discs yet. I found a vannette but he won't sell the brakes separately.
I haven't ever heard of the L300 scenario, where did you come across this info?
Posted on: 2008/6/1 6:52
691000 told me. i had a look they have similar front end.
Posted on: 2008/6/1 7:03
From Darwin NT
the nomad brakes will fit if you want to stuff around with it and it will give you around 3 deg of negative camber
what you needs is
1600 tie rod ends
and the upper and lower ball joints from the c22
modify the upper and lower control arms to accomadate the new ball joints
also the steering arm is up higher then that of the original 1000 front so this may affect something at some point
Posted on: 2008/6/1 8:16
current project 4x4 patrol...
Okay, have you got yours set up yet dattoVB10?
Posted on: 2008/6/1 12:02
From Darwin NT
no i think i might just can the conversion or i may do it i am not sure
Posted on: 2008/6/1 12:48
