« 1 (2)
Re: WANTED R31 handbrake pics
Mildman posted this pic although I have no idea where it's origin is but the concept is there. You will need to get 2 cables made though. You should get change from $200
Posted on: 2008/6/2 12:51
From Geelong, Vic
mildman??? thats short-coupe's car
Posted on: 2008/6/2 12:58
I don't know whose it is. I just found the pic here
Posted on: 2008/6/2 13:02
From Melbourne,Australia
Im using standard r31 cables that go along the axel tubes on the diff and then into custom brackets that i made which are welded to the underside of the floor.They then go to a splitter cable that i had made and is operated by a modified 120y cable sort of hard to explain il try to get some pics over the w'end
Posted on: 2008/6/3 2:31
From Geelong, Vic
mmm pics flowing in every where
Posted on: 2008/6/19 4:57
From Nyngan, nsw Australia
kool throw sum pic's my way, i think you will find that the guys dont want to give there ideas away,....A FELLAS ENTHUSIAST
i have altered the R31 handbrake lever to fit to the original 1200 cable in the cab looks heaps better,...
the rivet are slightly larger on the r31, machineing up sum new ones..
Posted on: 2008/6/19 8:43
« 1 (2)
