« 1 (2)
Re: replacement gaurds
Ah, thanks. Now I see what it is in the Nissan catalog. There is also a Sealer-front fender PN 63811-H1000.
Posted on: 2003/6/7 6:22
From Auckland N.Z
im serously interested in the fiberglass option there 1200rallycar so give me a bell when youve got your little production line up and running. gx stuffs imposable to come accross in nz. so fiberglass is all good.
Posted on: 2003/6/7 15:57
From Christchurch New Zealand
fiberglass is about the same weight as the metal guards on a 1200 since they are so thin .
ps fiberglass cracks on impact
Posted on: 2003/6/8 4:15
"If your not living on the edge your taking up too much space" Rod Millen
Not too shy to talk
From Townsville
My old rusty bonnet weighs 10.5 kg and my new non-genuine weighs about the same (10kg). What weight would a fibre glass one be?
Apart from the small weight reduction the only other reason I see to build a fibre glass bonnet would be to incorporate some vents to get better air flow through the engine bay.
Posted on: 2003/6/8 5:07
Leon
Not too shy to talk
From Brisbane
Fibreglass guards don't dent when you lean on them to work under the bonnet either!
Posted on: 2003/6/8 10:29
From Auckland N.Z
i just want a gx bonnet and i doubt ill find one in nz for sensible $$ so f/glass is probably easer and cheeper.
Posted on: 2003/6/8 14:15
« 1 (2)
