Browsing this Thread:
1 Anonymous Users
TRX WHEELS = what size tyre to run |
From Adelaide
hey guys,
i have tried searching already but didnt come up with much bout tyre size for trx wheels on a ute,
seen one bit bout running 185 40.. at the moment i got 13's and there 175 70 or 70
but at the same time they scrap on the firewall.
so has anyone got tyre size they ran?
Posted on: 2008/6/6 9:31
Re: TRX WHEELS = what size tyre to run |
From Canberra
With absolutely no supporting evidence I would recommend 195/45s on the front and 195/50s on the back.
Posted on: 2008/6/6 9:34
From Tamworth , NSW
maybe a leeeeetle off track but check this tyre sizesmay give you an idea of what is close to what your running now
Posted on: 2008/6/6 9:48
From Adelaide
yeh i no of that site, but the reason im asking as i said coz the tyres i got now on my 13's scrap on the firewall
Posted on: 2008/6/6 9:52
From Canberra
if you've got the bare rims ready to go, maybe go to a small tyre shop on a slow day and see if they'll trial fit a few different sizes for you to see what works best. A couple of shops in canberra have done that for me and seemed happy to do so.
Posted on: 2008/6/6 10:04
From brisbane, qld
U can go down to a 165/50/15 if you want something real close to the original rolling diameter, but a decent brand 195/50/15 will work, thats what ive got on my ute, but it every so often touches the front bottom corner of the wheel arch of the guard. I run a stanza front disc set up atm. You could also try a 185/55/15, im swapping to these, i just have to fit them. U could even go for a 175/55 i think.
Ultimately i would be fitting the 165/50/15's on the front(potenzas) and probably 185 potenzas on the back or maybe a 195/45 as they are grippy and you dont really need much more with a decent tyre, but they are up around the 200 mark a piece. But u will generally need to order them in so testing may not be an option. Most tyre shops wont carry the more uncommon sizes, but u can get them.
Posted on: 2008/6/6 12:07
From Bathurst - NSW
i run the same 195/50/15 on trx rims with stanza struts, its rub a couple of times on decent lock with a big bump, just touches the paint. I put the 12" kidney beans on today and actually liked the "feel" of them a lot better.
Posted on: 2008/6/6 12:33
From Far, far away
On my ute with 120Y struts I ran the 195/45 rubber with no probs.
I wanted to go 185/40, but the price was off putting. Something like $40-$50 more each, and I get my tyres cheap.
Posted on: 2008/6/6 14:44
From south coast, nsw
i have tried both 195/50 and 195/45s on trx rims and found that the 195/50 did hit on the front edge of the gaurd. im running shortened stanza struts and lower control arms. so my recomendation is 195/45r15.
Posted on: 2008/6/6 22:43
From melbourne
I have run 185/55/15 front and 195/55/15 rears with no probs , i hadm disc brake front end using stanza struts.
Posted on: 2008/6/6 23:29
