old webber 28/36
Not too shy to talk
From brisbane
can anyone tell me if i can use the same jets/air correction ect....as a 32/36??
Posted on: 2008/6/12 6:10
Re: old webber 28/36
In what?
Posted on: 2008/6/12 10:16
Love your Datsun.
Treat it well.
Not too shy to talk
From brisbane
1971 1200 coupe with standard a12 motor.....the 28/36 dcd webber came out of a 120y wreck i bought some years ago (also had a 5 speed box & a14...paid $250 bucks for the lot) just wondering if any one knew if jet/emulsion/air corraction/fuel/idle/choke tube sizes (32/36 as discribed on wiki) would work on my 28/36...any know?
Posted on: 2008/6/12 13:11
Ahhhhh, mia culpa, I didn't read or absorb all that you had writen.
You have an older 28/36 & want to know if the specs for the 32/36 will work in it. NOW I underkastumble.
First thing, I suspect, is to determine if there is a problem with the carb as it is. With the smaller 28mm primary, it would have been intended for a smaller engine anyway, so it may well be close to the mark right out of the box for all we know.
I suggest that you fit it, drive it, then work from there. If it drives just fine, then you save yourself some grief & $$$.
Posted on: 2008/6/13 1:56
Love your Datsun.
Treat it well.
From Sydney
I would think that the jetting [from a 32/36] would indeed be very close to the money in your 28/36. Also as a added bonus you should see an improvement in the lower driving speeds and on slight throttle as the mixture velocities on the primary throat should be faster. If its on a street car then it should be a win win situation.
Posted on: 2008/6/13 3:21
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
I'm not 100% certain, but I think you can use DGV jets in a DCD.
I recommend you use the jets used in the B210. It should work just as well with your B110.
Posted on: 2008/6/13 5:14
