help- A15 J15
From Queanbeyan nsw 2620
hi, I wont to put a 1500cc motor in my 1200 ute, and i have found that there are two tyes A15 and J15 and i was wondering if any one no's if they are the same or not?? and will the J15 fit into a 1200
Posted on: 2003/6/10 13:45
Re: help- A15 J15
From Canberra, Australia
A all the way...
J15's suck from what I have heard.
And A series will be an easier swap anyway...
Posted on: 2003/6/10 13:52
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: help- A15 J15
From Melbourne, Australia
"D" knows a bit about j15's but basically i think lobsters got the right impression
Posted on: 2003/6/10 14:58
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: help- A15 J15
The A15 is a bolt-in. It bolts to the stock 1200 transmission, and the motor mounts are just a little different. The water pump, exhaust, etc is more or less the same.
The J15 is a different type of engine, it was in the early 1500 (520) pickup.
Posted on: 2003/6/11 4:41
Re: help- A15 J15
From Charlotte NC USA
the main differences between the engines aer inside (but verry importaint)
1. the J15 has only 3 main berrings A-series have 5
2. J-series have siamesed intake ports (not good for breathing A-series are an 8 port engine
3. a J-series engine will explode if you turn it over 5000rpm for more than an instant. A-series are designed to turn above 5000rpm all day.
My advice is to get the A-15 and let the antiquated pile of rust J-15 rot!!!
Posted on: 2003/6/11 11:44
Phil (aka nutcase)
I have C.L.W.E.A.
Can't Leave Well Enough Alone
120y exelant clone gone :(
