RWD SR16VE
Not too shy to talk
From NZ
Ill start a thread on how to do this, based on facts for those that are interested.
I no I could just swap heads but I want to stay in the 1600cc class.
As its a slow porgression Ill need to update everyso often.
I got an S14 SR20de complete engine.
Also a complete SR16ve.
The crank rods and pistons fit directly into the SR20 block
I had to grind the crank as one of the journels wasnt too flash & fitted acl bearings.
Fitted ARP rod bolts & basically just cleaned everything else up.
Cold tank block / new frost plugs etc: & power honed the bores.
Had to fit a plug in the rear oil return and a restrictor to the from oil supply.
Heres the block
Nest week I will close the engine up and post more pcxs
Posted on: 2008/6/21 3:11
Re: RWD SR16VE
From Wagga Wagga, NSW
Sounds brilliant mate is the motor for the sunny in your avatar?
Good luck
Jake
Posted on: 2008/6/21 3:13
Re: RWD SR16VE
Not too shy to talk
From NZ
Yes
http://smg.photobucket.com/albums/v20/IIIRII/th_Sunny_B310.jpg
The car is currently running A15 /78mm bore
With a S15 6 spped gearbox I have adapted to the A seriers engine.
I can retain the 6 speed by fitting a oem bellhousing which will bolt up to the Sr20 block.
This photo shows how the ve headgasket doesnt cover the rear oil return.
You can see the plugged part in the assembled block pcx
Whys it only posting the link and not the pcs ?
Posted on: 2008/6/21 3:33
Re: RWD SR16VE
view the photo at photobucket, right click on the image its self and click properties copy and paste the address from properties to the img insert button on the 1200 site and wala!
Hope ive helped
Jake
Posted on: 2008/6/21 3:54
Re: RWD SR16VE
Not too shy to talk
From NZ
Posted on: 2008/6/21 4:00
Re: RWD SR16VE
There ya go
Posted on: 2008/6/21 4:41
Re: RWD SR16VE
change IMG to lowercase img.
Or just use the IMG function button to link your pics
Posted on: 2008/6/21 5:38
Re: RWD SR16VE
Not too shy to talk
From NZ
Ve headgasket on de block
Posted on: 2008/6/21 6:07
Re: RWD SR16VE
hang on a minute... im a genius..
knowing that sr blocks will take any sr components ( i think ) are you telling me that if i had a sr16ve i could put in sr20det rods crank pistons etc?
also how close is the distributor sticking out the back of the head to the firewall?
Posted on: 2008/6/21 7:23
Re: RWD SR16VE
Not too shy to talk
From NZ
Yes
Posted on: 2008/6/21 8:56
