Bore size for A15
Not too shy to talk
From Bundaberg, QLD
hey
i was just wondering wat is the best size to get my engine bored out to .. with only having mild engine work done to it
thanks TrenT
Posted on: 2008/6/24 8:45
Re: Bore size for A15
Best size is no bore. Just hone the cylinders, and fit new rings.
You can bore it if the cylinders are exceptionally worn, but then you'll need to buy new oversize pistons.
Posted on: 2008/6/25 19:14
Ive cracked two bores with the right block compatibility. Its a waste of time and better stock as dd says so then u can boost it in the future.
Posted on: 2008/6/26 0:42
Not too shy to talk
From Bundaberg, QLD
ok thanks for the info
Posted on: 2008/6/26 7:51
