TX3 pistons in an A15
what would have 2 be done 2 put tx3 1.6L turbo pistons in my A15
Posted on: 2008/6/24 7:20
Re: TX3 pistons in an A15
From Christchurch NZ
What are the diamentions of the TX3 pistons?
IE, diameter, pin height, pin bore diameter.
Posted on: 2008/6/24 7:25
Forced Induction!
I dont nt have the pistons at this stage but the bore is 78mm and dont no pin bore dimeter. i saw that some guy had put some in an A15 race car. i am lookin at this as for i have a supercherger to fit my A15 and i want larger displacment as well as a piston that can handle the forced induction
Posted on: 2008/6/24 13:17
Not too shy to talk
From NZ
Its pretty easy.
Measure the pin / deck heights / diameter.
Go to engine reconditioner.
Ask for piston spec book.
Look at Ford tx3 ......
Probably has a 20mm pin so you need to resize l/e
I used Mazda 78mm uc pistons with .5mm off the squish.
Theres literally dozens of pistons you can use.
You might want a larger bowl in piston if you are s/c ing.
there are 2 options on the mazda pistons from memory h/c twincarb type and l/c single carb, maybe the l/c ones will work out ok.
you also need to know the head cc so you can work out real c/r.
Posted on: 2008/6/24 23:42
I think there is a ford/mazda piston which can be fitted with has a shorter pin height. This means decking the block to get the CR up, or not if you want a low CR. My next rebuild will be using pistons along these lines.
Although having pistons that are below deck height is not conducive to good squish characteristics.
Posted on: 2008/6/25 7:50
Forced Induction!
From Perth
The 1600cc B6 Mazda has a 78mm bore and a 20mm wrist pin
The pin height is 31.4mm so you have to shave some off to get down to the 30mm required for an A15
That being the case to get them suitable for boosted applications would mean taking too much off the crown to get down to an accesptable CR and compromise strength
STD and replacement aftermarket pistons for the B6 are just cast and nothing special unless you order forgies
If your ordering forgies then get them made to suit what you need... cost not much more for customs
Keep your comp around 8.5 (sounds suspiciosly like STD comp) and you could run up to 14lbs with some injection and a decent tune.(safely)
Posted on: 2008/6/25 10:28
I have some near new laser pistons which I was told by the guy I got the from would require the block decking. But I thought that fords and mazdas were pretty much the same.........
Posted on: 2008/6/25 10:54
Forced Induction!
