(1) 2 3 »
gx airbox hose locations
From Melbourne vic
Ok guys info needed from those in the know
(dodgeman!!) and anyone else. The early gx
b110 only has one hose-agreed? Now, the later
blue b210 flat type carb air box has
how many more? pictures? help would be
just fine-ta
Posted on: 2008/7/2 7:29
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
Re: gx airbox hose locations
From Sydney
Early GX inductions have three hoses, one from the PCV valve on the inlet manifold to the fitting on the rocker cover. Second hose goes from the fastory airbox to the crank case vent pipe and the third hose goes from the front of the inlet manifold to the water outlet [junction where the heater hose and bottom rad hose meet].
Clean air flows through the engine in the opposite direction to the regular engine config. clean filtered air enters via the block and exits via the rocker cover. The hoses are unique GX parts and are thin on the ground these days.
Posted on: 2008/7/2 7:56
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Melbourne vic
thanx, and the later b210 (blue air cleaner)?
Posted on: 2008/7/2 8:51
:Nice
From Melbourne vic
bump
Posted on: 2008/7/2 12:32
:Nice
Same for B210.
<-- wiki clicky Hitachi Twin Carb
Posted on: 2008/7/2 17:13
From Melbourne vic
so all gx airboxes only have one outlet
and the differences for emissions are
extra hoses on the carbs-is that right?
Posted on: 2008/7/2 23:44
:Nice
It seems no one knows for sure. Most of us have only seen one kind. Going by the photos, I think that is true, all the airboxes are the same more or less.
Posted on: 2008/7/3 3:11
From Sydney
On the later GX air boxes. the fuel bowl overflow pipes also vent into the airbox.
Posted on: 2008/7/3 3:18
1970 KB10 Coupe
S13 caliper b...
From Melbourne vic
do you mean later a12 gx or a14gx
does some one have a photo of the
later type backing plate that has more
than one outlet??
Posted on: 2008/7/3 3:39
:Nice
From Sydney
I personally only own the early A12GX type. I think Dodgeman may have all three examples, if not, he should have pictures of all three atleast.
Posted on: 2008/7/3 3:41
1970 KB10 Coupe
S13 caliper b...
(1) 2 3 »
