new toy
Not too shy to talk
From Kaikohe Northland
Race datsun A-series cylinder head assembly, port matched sidedraft inlet manifold, sidedraft carbs package.head has had a lot of work done to it including:
Skimmed surface to raise compression
Heavily raised porting
Ported oil galleries for better flow
Very large valves (40mm in 33mm ex),
Double valve springs
New valve stem seals
Rocker springs have been replaced with shims
Sidedraft inlet manfold has been port matched to head. Sidedraft Mikuni carbs with newly fitted needles and seats from USA. Were run on race A15 (1608cc) previously. Come with shiney trumpets. does anyone know if this size porting will work on a 1200, my last build a number of years ago, was with a GX head with 37mm/29mm and not as much porting, this porting is huge.
Posted on: 2008/7/7 3:31
Re: new toy
Will it work on a 1200? Sure, if it is a racing 1200 and you are running very high RPM.
Posted on: 2008/7/7 5:06
Re: new toy
From Christchurch NZ
Sounds like you're considering buying Chris Cain's (AKA Cheater 5) race head.
That head is a pretty serious piece of kit. It wouldn't be real flash on a street motor, especially if you were running a cam that yielded low manifold vacuum.
It would be bad as on a forced induction motor. If I win the lotto, I'd buy it in a snap.
Posted on: 2008/7/7 6:33
Forced Induction!
Re: new toy
Not too shy to talk
From warwick
how much power does it have?
Posted on: 2008/7/8 7:14
Re: new toy
From Tamworth , NSW
power? as its just a head id say it has none
its not just a head that makes power you need the rest of the engine too.
Posted on: 2008/7/8 7:21
Re: new toy
Not too shy to talk
From warwick
ha
i thought it was on an engine
Posted on: 2008/7/8 7:24
