(1) 2 3 4 »
what gearbox is it?
From Melbourne, Australia
i got a 5-speed a while ago and cleaned it up tonight to see which one it is exactly
i cant find any obvious markings that tell me
all i could find was a "7" on either side of the centre section and a "1" just near where the reverse light switch thingy screws in, then etched into the top on the flange "18"
could be dogleg pattern not sure
does anyone know which box it might be???
1:1? 60a?
i dunno???
Posted on: 2003/6/15 12:58
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: what gearbox is it?
From Gold Coast Aust
Do we asume it bolts up to a stand gearbox mount? Have you tryed a tail sharft into it?
and is it the same lenght as a standard box?
Posted on: 2003/6/15 13:07
Datsun 1200
Keepin' the past in the future
sorry yeah i got it off the back of an a-12, seems to have standard rear crossmember on it and it came out of a manual tunnel
i havent tried a tailshaft yet, but had thought of that
not sure of length
it was a 120y a-12 and also had 120y borg warner diff in car
i didn't get the tailshaft, hopefully i dont need it
Posted on: 2003/6/15 13:10
1200 Coupe Rallycar
I had a 5 speed the same years ago it was given to me and the fella that gave it to said it was 120y and I sold it a year later and never thought about it again untill you metioned it It did have different stamps on it but I didn't want to say it was 120y for fear of being wrong I didn't know we had 5 speed 120y's here Could it be import?
Posted on: 2003/6/15 13:34
Datsun 1200
yeah i would have told you you were wrong, until now im not sure, hope they are good gearboxes
anyone else know????
Posted on: 2003/6/15 13:39
1200 Coupe Rallycar
the tech section mentions a 120y one
This means the 1974-1978 B210 (120Y)
but i dont think that was an aussie option (article written by someone in US)
Posted on: 2003/6/15 14:09
1200 Coupe Rallycar
Chris (Dattodude) will know wait 'till tommorrow
Posted on: 2003/6/15 14:11
Datsun 1200
From Sydney, Australia
I've played around with 120Y stuff a long time in the past, but I didn't think they had a 5 speed either. It might have been an import Option. Only reason I say that is the 200Bs of a similar vintage had variations in brakes etc, as they were assembled here and overseas. We once discussed the "local content" laws for car manufacturers, that meant if they wanted to assemble here, they had to use a percentage of Australian made parts. So my long buy short answer is that I don't know.
Please get some "white-out" (tippex) and mark the output shaft across a radius. Push a clutch plate over the inputshaft and mark it too..If it's still connected to the flywheel, use the whole flywheel. Put it in first gear and turn the flywheel 10 times, counting the output shaft revolutions. Do this for each gear, but most importantly do it for 5th gear. This will give us an idea of what box it is based on the ratio of 5th.
Chris
Posted on: 2003/6/15 15:20
will do
Posted on: 2003/6/16 10:29
1200 Coupe Rallycar
feral i see your online, do you know, you say in the other thread there is no b210 5-speed???
Posted on: 2003/6/16 14:50
1200 Coupe Rallycar
(1) 2 3 4 »
