new cam valve lifters, where and how much?
From melbourne VIC
Hi,
I'm after a new set of valve lifters (cam tappets) for an A15.
I've been told that they are exactly the same as the A12 lifters, can any1 confirm this?
Are these still available from the local nissan spare parts dealer?
Any idea of the part number and the cost?
I know that they can be re-surfaced but i was after new one's if the price is right.
Any help would be much appreciated
cheers
Posted on: 2008/7/18 5:58
Re: new cam valve lifters, where and how much?
They have same part number
Nissan Dealer Part Number:
13231-H1001 1970-1983 A12, A14, A15
Posted on: 2008/7/18 6:44
From NZ
I have seen 2 slightly different sorts:
one has chamfered edges on the mushroom;
other is square edged (the later one I think).
I found this out when replacing a damaged one in my race engine. I doubt it would matter to have an unmatched set in a standard engine though.
Can't see why you'd want to replace with new unless damaged - resurfacing by cam / machine specialist is inexpensive and as good as new.
Posted on: 2008/7/18 10:57
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
