Crank Pulley for use with Super Charger
From Perth
Anyone found a crank pulley for a A15 to use with a super charger? Looking at getting a machine shop to cut down a double datsun pulley and graft the super charger drive pulley on to it. Thought someone may have found an easier way.
Posted on: 2008/8/6 12:18
Glen
Morris Minor, Datsun 1500, Supercharged, 5 speed.
Re: Crank Pulley for use with Super Charger
From sydney
yep i do u can use the standard datsun crank pulley and weld a pulley on it from a toyota corolla 4wd wagon water pump. i dont know wat year it is but ill try find out.
Posted on: 2008/8/6 12:25
TYR-33D (SLEEPA)
Some is good,
More is better
And too much is just enough
Stroked is nice but id'e rather be Blown
From Perth
I was told that most pulley's are made from cast iron so welding is not a good option, also there could be a problem with the pulley being out of balance. By the way, nice ute.
Posted on: 2008/8/6 12:29
Glen
If you're in Melbourne there is a place in Bayswater called Power Transmission & Belting Service 03 9762 0722
They would have just about any type of pulley type you require, if not they could probably make something up for you.
I just had a belt drive crank pulley made by them, cost me $85 + gst.
Posted on: 2008/8/6 12:35
From Perth
No in Perth but I may try the phone book and look for some places that do pulley's over here.
Posted on: 2008/8/6 12:40
Glen
From Christchurch NZ
The dual pulley pulley isn't the magic bullet it should be for would be superchargers.
The outer pulley is hollow. I started off with an al alluminium pulley, with the ribbed blower belt pulley bolted to it. It had a speedy sleeve over it to protect it from being worn by the crank pulley seal. But this meant that the land was too thin in the valley of the keyway, and it blew out. So now I have a steel boss, with both an aluminium crank pulley, and blower pulley bolted to it. I could probably get you a sharp deal on having some made, but postage would kill it.
Posted on: 2008/8/8 6:43
Forced Induction!
