Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#21
Re: 1200 Coupe Blue Slip Progress
DatsAndy
Posted on: 2008/8/7 12:40
yeah for sure. So are you mate it was your little tip that helped me finally get the picture up. Will update with more as it goes along.
#22
ROConnor
Posted on: 2008/8/7 12:42
HAHA! cheer's, I gota get started on some bits for my sedan soon, might allso start a project thread??
#24
DatsAndy
Posted on: 2008/8/7 13:55
#25
supafatto
Posted on: 2008/8/8 12:39
good lookin car
i still gotta work out how to post pics its lookin good wit all the stuff
#26
DatsAndy
Posted on: 2008/8/9 9:44
Apart from spending Half the day under the dash re fitting the wiring harness and fixing any exposed or bodgy other wiring with solder and Heat shrink. Repaired (Plastic Welded) a crack in the Dash Fascia masked it up Prepsoled and painted it Satin Black Plastic paint.
Masked Up, First Coat ![]() After 3rd Coat Unmasked And Different Lighting ![]() Engine Bay Tidy Up Tomorrow ![]()
#27
DatsAndy
Posted on: 2008/8/9 10:29
Also. Special Thanks To Sidedraught for his help with the pics
#28
ROConnor
Posted on: 2008/8/9 11:04
Hey andy, do you know what radiator that is? could you take some pics of how it mount's? and maybe where some body has bin cut?
Thanks..
#29
DatsAndy
Posted on: 2008/8/9 11:32
Mate Im not sure i can give away that info. HA HA Just kidding. The radiator Is HQ Holden With a custom Aluminum overflow. Will take pics of it for ya and add them here. Its a pretty simple fit Just 4 bolts through rubber bush type things and the Radiator support panel has basically just been smoothed and a piece cut out of the top support and smoothed to recess it back from the motor. Hope that makes sense i know what i mean. We have a VC commodore Radiator here and VL commodore Radiator if ya keen. Will check if there similar as far as the top and bottom water hoses go and mounting but i think they slide in.
#30
supafatto
Posted on: 2008/8/10 13:22
hey did no that you can also use a n13 plusar radiator wit twin thurmo as well it fits in and works the bomb!! i did this in my old coupe gonna do it 2 the sedan 2 as mine is stock
