needed: sunny/stanza lca's, ball joints
From Adelaide
as above, need the gear as soon as posible.
Kym
Posted on: 2008/8/13 12:42
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
Re: needed: sunny/stanza lca's, ball joints
From Geelong, Vic
cant buy balljoints new?
Posted on: 2008/8/13 12:45
From Adelaide
Yeah, what else do I need to fit 280zx struts?
Posted on: 2008/8/13 13:31
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
From Adelaide, Australia
Late model 120y or later ute radius rods, stanza/sunny steering arms and outer rod end. You've removed the spring seat?
Posted on: 2008/8/13 13:34
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Adelaide
Yeah spring seats are off. I wanted a heavier rated springs, what fits (spring dia 110mm)? I was just going to weld the 1200 spring seats on and buy some new heavier springs? ideas???
also what's classified as late model in a 120y
Posted on: 2008/8/13 13:47
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
From Geelong, Vic
ill be selling a whole setup to bolt the struts in soon
late is after 76 i think, they use 17mm headed bolts to holt the balljoint onto the control arm instead of 12 or 14mm
200b rear springs with the progressive part cut off are good to use in place of 1200 springs
Posted on: 2008/8/13 13:52
After 76 I think, they should just have the same length as a 1200 item just the larger bolt size and spacing for the balljoint.
Any stock rear 180b/1600 spring is pretty firm, so are front 240/260/280z springs, I think they are rated to around mid 100lb.
Posted on: 2008/8/13 13:54
IPRA Build
From Adelaide
Cheers
Posted on: 2008/8/13 13:56
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
From Adelaide
We have all parts needed in stock.
Scott
Posted on: 2008/8/13 14:36
From Adelaide
Hey Scott, could you please send me a pm with all the prices for the parts needed.
Cheers,
Kym
Posted on: 2008/8/14 0:22
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
