frankthedolphintrainer wrote:
i think your meant to put a a12 gx head on an a14 because it has higher compression but still has oval ports plus the big valves
The cylinder heads that were used on the 1200 GX & the A12T [120Y GX] used the largest of the production port sizes & were equal to the smallest of combustion chamber sizes but still used the standard A10 & A12 valve diameters of 35 & 29mm, so fitting an A12T head to an A14/15 engine is not automatically an upgrade as the engine now has smaller valves compared to the A14/15's original size.
Even if the compression ratio was unchanged, the fitting of the 'good' A14 head to an A12 engine is also NOT going to necessarily increase power. It will, however, remove the small port & small valve size restriction of the original head & allow other mods [carb, cam & exhaust] to unlock the potential of the smaller engine.
Anyone who thinks that simply fitting an A14 head is going to provide noticeable power gains just by itself, ... is dreaming.
